![]() | Home > Technical > exhaust manifold gasket |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
If there were a v6, (probably similar) what you would do is:
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
when I jack it up do I put it full height so it don't throw a suspension fault when I'm done |
and with out sounding totally stupid what should I take pictures of and mark |
Access height is fine. You may need to lower the car part way to work under the hood.
thanks for that kind sir I'll make sure pictures are taken |
