Home > Technical > exhaust manifold gasket
karlos01
got a ticking coming from engine on my 4.2 supercharger V8 from the passenger side I've pinpointed it down to exhaust manifold gasket
has any one changed one before and is it a pig of a job to do
I am a bit mechanical minded so just wondered on time scale to do the job
Post #626185 Fri Aug 19 2022 8:07pm
If there were a v6, (probably similar) what you would do is:
Remove the heatshields in the wheel arch, (jack up, axel stands, remove wheel) but first mark them with numbers and take a photo in situ
and also make intersecting marks. They are a true jigsaw! Will save a lot of time later.
Purchase a long ratchet extension 24 inches or more.
undo the manifold bolts through the wheel arch.
you may need to undo the other end of exhaust from the cat too
Post #626191 Sat Aug 20 2022 7:38am
karlos01
when I jack it up do I put it full height so it don't throw a suspension fault when I'm done
Post #626192 Sat Aug 20 2022 8:11am
karlos01
and with out sounding totally stupid what should I take pictures of and mark
Post #626193 Sat Aug 20 2022 8:13am
Access height is fine. You may need to lower the car part way to work under the hood.
Take pictures of silver foil heat shields
Post #626194 Sat Aug 20 2022 10:18am
karlos01
thanks for that kind sir I'll make sure pictures are taken
Post #626198 Sat Aug 20 2022 12:04pm
