Home > Technical > Hdc fault. No quick fix
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi all, I've the 3 amigos on my dash but only after getting to 25 or 30mph. Not there at initial start up. I also get a grinding and crunchy abs noise on my left side front. I've changed battery, front abs sensor and brake light switch all to no avail. I'm now thinking it may be outer cv joint with the abs cogs on but not sure. Sometimes the traction control flashes first a couple of times then all three pop up.
Any ideas or is it a trip to a dealer +
Car is 2008 2.7 sport
Post #625369 Tue Jul 12 2022 5:02pm
Mickmac
England 2007 Range Rover Sport TDV6 HSE Java Black
I had the same symptoms,turned out to be a wheel bearing ,worth a check
Post #625373 Tue Jul 12 2022 9:23pm
Toonraider
Forgot to mention, new wheel bearings both fronts and all new discs and pads.
Post #625374 Tue Jul 12 2022 9:29pm
Toonraider
I can replicate this with ease. Strangely.
Accelerate up to 30 and it kicks in straightaway, suspension drops, no progs etc... Help.
Post #625413 Thu Jul 14 2022 10:18am
Does the suspension drop to the stops?
That sounds like a cross axle articulation error - the system thinks you're cross axled and drops the car / limits performance to prevent you going too quickly and crashing.
It's often caused by a calibration issue with the air suspension module although you can be unlucky and have two height sensors in failure and that will cause it.
If you put the 4x4 info up on the screen, does it show anything other than a level car with white lines above and below the wheels?
It might be a simple calibration required or it might be a sensor issue. If a sensor is replaced the system needs to be recalibrated anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #625416 Thu Jul 14 2022 12:21pm
Toonraider
Hi,
Shows the car as normal and level, and wheels turn on screen to match what I'm doing with steering inputs.
Post #625432 Fri Jul 15 2022 7:07am
Toonraider
Yeah, white lines above and below each wheel and red boxes across the axles.
Post #625433 Fri Jul 15 2022 7:08am
karlos01
should look like this in normal ride height
Post #625436 Fri Jul 15 2022 10:15am
Toonraider
Almost certain mine shows the same. Will put a pic later if I can work it lol
Post #625454 Fri Jul 15 2022 7:06pm
Toonraider
Here's mine before it falters.
Post #625456 Fri Jul 15 2022 7:08pm
Toonraider
Ha, knew I'd cock it up
Censored
It's the same as yours tho.
Post #625457 Fri Jul 15 2022 7:11pm
karlos01
have you got anyone near you who with a diagnostic and see what fault cods you come up with?
Post #625459 Fri Jul 15 2022 8:04pm
Toonraider
Seeing someone on Sunday but with an icarsoft system.
Post #625462 Sat Jul 16 2022 6:57am
karlos01
that should help you out with a fault code
hope you get it sorted out
Post #625465 Sat Jul 16 2022 7:54am
Try pressing the dsc button before you set off
May help as a temporary work around
Post #625468 Sat Jul 16 2022 8:33am
