Home > Technical > Hdc fault. No quick fix |
Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16 |
I had the same symptoms,turned out to be a wheel bearing ,worth a check |
Tue Jul 12 2022 8:23pm |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
Forgot to mention, new wheel bearings both fronts and all new discs and pads. |
Tue Jul 12 2022 8:29pm |
I can replicate this with ease. Strangely.
Thu Jul 14 2022 9:18am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
Does the suspension drop to the stops?
Thu Jul 14 2022 11:21am |
Fri Jul 15 2022 6:07am |
Yeah, white lines above and below each wheel and red boxes across the axles. |
Fri Jul 15 2022 6:08am |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
Fri Jul 15 2022 9:15am |
Almost certain mine shows the same. Will put a pic later if I can work it lol |
Fri Jul 15 2022 6:06pm |
Here's mine before it falters. |
Fri Jul 15 2022 6:08pm |
Ha, knew I'd cock it up
Fri Jul 15 2022 6:11pm |
have you got anyone near you who with a diagnostic and see what fault cods you come up with? |
Fri Jul 15 2022 7:04pm |
Seeing someone on Sunday but with an icarsoft system. |
Sat Jul 16 2022 5:57am |
that should help you out with a fault code
Sat Jul 16 2022 6:54am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Try pressing the dsc button before you set off
Sat Jul 16 2022 7:33am |
