![]() | Home > Technical > Hdc fault. No quick fix |
Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16 ![]() ![]() ![]() |
I had the same symptoms,turned out to be a wheel bearing ,worth a check |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 107 ![]() ![]() ![]() |
Forgot to mention, new wheel bearings both fronts and all new discs and pads. |
I can replicate this with ease. Strangely.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Does the suspension drop to the stops?
Yeah, white lines above and below each wheel and red boxes across the axles. |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
Almost certain mine shows the same. Will put a pic later if I can work it lol |
Here's mine before it falters. |
Ha, knew I'd cock it up
have you got anyone near you who with a diagnostic and see what fault cods you come up with? |
Seeing someone on Sunday but with an icarsoft system. |
that should help you out with a fault code
Try pressing the dsc button before you set off
