![]() | Home > Technical > Key fob central locking |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
The emergency lock situation is normal.
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 101 ![]() ![]() ![]() |
Cheers for that. I'm gonna check that splice tomorrow. 👍 |
Tried the sync as,
OK success! Found the splice, even though mine only had two. Chopped, stripped and soldered, job done. Happy.
Door locks are unreliable on these and need changing lots. You can get cheap latches new on eBay.
Thanks for the reply. So I need to remove the scuttle cover trim first yes?
Check round the door seal for any rust signs or water.
Thanks for the tips, I will tackle this on Thursday. |
Door seal seems fine, so I've done the A bar modding and the air intake under the windscreen so hopefully that should be the end of water ingress. |
