Home > Technical > Key fob central locking |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
The emergency lock situation is normal.
Sun May 15 2022 4:08pm |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
Cheers for that. I'm gonna check that splice tomorrow. 👍 |
Sun May 15 2022 7:46pm |
Tried the sync as,
Sun May 15 2022 7:48pm |
OK success! Found the splice, even though mine only had two. Chopped, stripped and soldered, job done. Happy.
Tue May 17 2022 8:19am |
Door locks are unreliable on these and need changing lots. You can get cheap latches new on eBay.
Tue May 17 2022 9:10am |
Thanks for the reply. So I need to remove the scuttle cover trim first yes?
Tue May 17 2022 12:27pm |
Check round the door seal for any rust signs or water.
Tue May 17 2022 2:55pm |
Thanks for the tips, I will tackle this on Thursday. |
Tue May 17 2022 5:36pm |
Door seal seems fine, so I've done the A bar modding and the air intake under the windscreen so hopefully that should be the end of water ingress. |
Mon May 23 2022 8:46pm |
