![]() | Home > Technical > 2014 RR Sport Autobiography Pan Roof. Error B13CB |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68 ![]() ![]() |
I have the same problem. Blind stuck in open position - what’s the reset procedure for that? Any help would be amazing. Thank you |
Russtyp Member Since: 13 May 2022 Location: Caerphilly Posts: 19 ![]() ![]() |
The reset instructions from the workshop manual are
mancsfinest Member Since: 28 Nov 2021 Location: Manchester Posts: 8 ![]() ![]() ![]() |
Hi mate. I tried the reset option but never worked for me. Took it to an independent in the end. They removed headliner and found a wire that had a cut in it, shorting on the metal. |
Thanks both.
