Home > Technical > 2014 RR Sport Autobiography Pan Roof. Error B13CB
mancsfinest
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Afternoon All. Wonder if anyone has had issues with their sunroof & blind. Mine worked normally until trying it recently and now, no joy. icarsoft error as shown in pic. I've checked to make sure both plugs are in securely, which they are. Fuse 10 & 12 checked. I've tried the reset procedure of holding the roof button for 20 secs. The roof does make a 1 second noise as if it's opening but nothing else. The instructions are, to do it with blind closed, but that is stuck in the open position!! TIA
Post #622861 Wed Mar 16 2022 3:15pm
 2012 SDV6 - it's missing a couple of cylinders
Post #622886 Thu Mar 17 2022 7:47pm
hario69
Re: 2014 RR Sport Autobiography Pan Roof. Error B13CB
I have the same problem. Blind stuck in open position - what’s the reset procedure for that? Any help would be amazing. Thank you
Post #633776 Fri Jun 16 2023 7:02pm
Russtyp
The reset instructions from the workshop manual are
Once the power supply is restored, reset the roof mechanism as follows:
o Turn ignition on.
o Roof opening panel and roof opening panel blind system must be in closed position. (If not, use overheadswitches to close both).
o Press "Roof" close switch for 20+ seconds until the roof opening panel blind actuates rearwards and then forwards about 10mm
o Release "Roof" close switch and re-press "Roof" close switch again within 5 sec and keep pressed until the following sequence has completed.
o Roof opening panel blind opens fully.
o Roof opening panel opens fully.
o Roof opening panel closes fully.
o Roof opening panel blind closes fully.
o Release switch, roof is now fully initialized.
Post #633781 Fri Jun 16 2023 10:38pm
mancsfinest
Hi mate. I tried the reset option but never worked for me. Took it to an independent in the end. They removed headliner and found a wire that had a cut in it, shorting on the metal.
Post #633783 Sat Jun 17 2023 5:35am
hario69
Thanks both.
If tried this and it doesn’t work, the sunroof blind is in the open position and that’s the problem.
Any ideas? Cheers!!
Post #633787 Sat Jun 17 2023 12:38pm
mancsfinest
Blind stuck open was the same for me, as well as roof not working, so couldn't complete the reset. Best taking it to an auto electrician to find the break in circuit bud.
Wasn't covered by warranty typically!! Crying or Very sad
Post #633804 Sun Jun 18 2023 8:07am
