Home > In Car Electronics > General Power/Electronics Issue
djpgowrie
I've got an issue with interior lights flickering (under door/sill light & speedo/rev counter backlight) along with the trip computer auto resetting after every journey.
I had the same issue a while ago so I decided to get a new battery. This didnt fix the issue at first but then somehow weeks later the trip computer started behaving.
More recently I had an error for something like 'charging circuit' and during a trip the car's electronics slowly died one by one until I had nothing. I got a new alternator fitted which sorted it but brought back the flickering lights and trip computer reset.
Does anyone know what could be causing this with a new battery less than 12 months old and a new alternator less than a month old? Maybe a faulty ground wire? ECU reset of some sort?
Post #621128 Thu Jan 20 2022 4:02pm
Did you fit a genuine denso alternator. ?
If no. That’s probably it
Post #621137 Thu Jan 20 2022 8:42pm
djpgowrie
Yep - I used this one:
https://www.island-4x4.co.uk/alternator-td...30382.html
If it was the alternator I would have thought that the problem wouldnt have occured both before and after a new one. With the car having a new battery and alternator then I would hope its neither of these two?
Post #621159 Fri Jan 21 2022 1:17pm
Disco_Mikey
Did you reset the BMS when the battery was replaced?
Post #621161 Fri Jan 21 2022 1:49pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Sorry to hijack, how do you reset the BMS? I changed my battery and didnt do it. have no issues but dont want to kill it prematurely
Post #621171 Fri Jan 21 2022 3:18pm
djpgowrie
No I didn't - I've done some googling and looks like i need a £120+ IID Tool?!
Would an OBDII be able to do it?
Post #621177 Fri Jan 21 2022 4:57pm
I fitted a new battery to mine before shipping car to NZ and never bothered to reset the BMS, have not had any problems and still starts first time, every time and that was 5 years ago, just made sure battery was fully charged before fitting it.
Post #621186 Fri Jan 21 2022 9:33pm
djpgowrie
So I have a basic OBD2 tool that reads and clears codes with nothing else. I've done some reading and ended up going for the icarsoft LR V2.0 unit. This has the BMS feature mentioned above and after checking the documentation my model should be fine to work with it. I think this could also be linked to my problems as the new battery I bought last year is a different CCA and capacity than the original
It also has Steering Angle Sensor function which my cars been complaining about since I got it so hopefully I can kill 2 birds with one diagnostic tool!
I'll give more of an update when the tool arrives in case it's worth something to anyone else in this position.
Post #621219 Sun Jan 23 2022 10:20am
karlos01
djpgowrie
be good to know if the ircarsoft diagnostic works as I'm looking for a diagnostic kit for my RRS sadly my brother in law has hawkey total and it not compatible with mine as can't get the dongles for it anymore
Post #621220 Sun Jan 23 2022 11:36am
