![]() | Home > In Car Electronics > General Power/Electronics Issue |
Did you fit a genuine denso alternator. ?
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 43 ![]() ![]() ![]() |
Yep - I used this one:
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Did you reset the BMS when the battery was replaced? |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Sorry to hijack, how do you reset the BMS? I changed my battery and didnt do it. have no issues but dont want to kill it prematurely |
No I didn't - I've done some googling and looks like i need a £120+ IID Tool?! Would an OBDII be able to do it? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I fitted a new battery to mine before shipping car to NZ and never bothered to reset the BMS, have not had any problems and still starts first time, every time and that was 5 years ago, just made sure battery was fully charged before fitting it. Cheers Col |
So I have a basic OBD2 tool that reads and clears codes with nothing else. I've done some reading and ended up going for the icarsoft LR V2.0 unit. This has the BMS feature mentioned above and after checking the documentation my model should be fine to work with it. I think this could also be linked to my problems as the new battery I bought last year is a different CCA and capacity than the original
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
djpgowrie
