Home > General > FBH is mine functioning ?
Stand Easy
Vehicle is a 2010 3.0 TDV6, I've searched the subject on here but can't find the answer.
How do I know my FBH is working as it should, I've no idea how to switch it on so consequently I've no idea Embarassed
Post #620819 Tue Jan 11 2022 2:44pm
When it’s around 4C or lower and you start the engine there should be smoke under the front of the car and an odd smell.
Post #620821 Tue Jan 11 2022 2:59pm
PEACHY
Do you have the option to set the timer via the infotainment screen? The other option is a plipper that allows an instant start up of the FBH. Thumbs Up 16MY Estoril Blue SVR.............
Post #620822 Tue Jan 11 2022 3:13pm
Stand Easy
Never noticed this, had the vehicle almost 3 years
Peachy
I've never seen the on screen option for the FBH, can you direct me to where that should be, no remote either Question
Post #620823 Tue Jan 11 2022 3:42pm
PEACHY
If I remember it’s located under the extra functions icon & then timed climate - is it definitely fitted to the RRS Laughing 16MY Estoril Blue SVR.............
Post #620824 Tue Jan 11 2022 3:53pm
The FBH doesn't always smoke - indeed I'd say it shouldn't smoke if running correctly.
Mine works and doesn't smoke and there's little, if any, smell either. A bit of condensation can be seen in the FBH exhaust stream if the vehicle is left running on a cold morning just after starting up.
Best way to see if it's working is to lift the bonnet a minute or so after starting the engine on a cold (6deg C or less) morning. You'll hear it running. Alternatively, a minute after turning on the engine on a cold morning, put your hand below the small pipe sticking down in the near side wheel arch. You'll feel the exhaust gases. 2012 SDV6 - it's missing a couple of cylinders
Post #620827 Tue Jan 11 2022 4:40pm
Stand Easy
Assuming this is the FBH then yes I have one Rolling with laughter
Can't find anything in the info settings Big Cry
Post #620831 Tue Jan 11 2022 5:28pm
see at 8 mins
removing the FBH fuse under the bonnet for at least 30 secs should reset it
Post #620832 Tue Jan 11 2022 5:36pm
Stand Easy
Thanks Andy, very helpful. Having watched the video, I have heard it running in the past and noticed the snowflake on the dash, it however doesn't have the option for timed settings, possibly something that can be done via a software update
Post #620835 Tue Jan 11 2022 6:12pm
The snow flake just indicates it’s 4C of lower and to drive carefully as roads maybe icy
Post #620836 Tue Jan 11 2022 6:23pm
Stand Easy
Ye of course, next time it's below 4 I'll make a point of listening for it kicking in Thumbs Up
Post #620837 Tue Jan 11 2022 6:33pm
https://www.gap-diagnostic.com/avada_faq/h...park-heat/
If you have a gap iid
Post #620838 Tue Jan 11 2022 6:35pm
riverblanche
Hi,
in your picture the FBH exhaust is at the very bottom with the pipe to it on the right from the unit itself, the pipe on the left is the air intake, so you can Carefully Whistle check to see if the exhaust gets hot to check if its running
you can also connect to it via webasto software from memory its using the Red wire which you have on your unit if you want another way to play investigate it Laughing
 Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #620864 Wed Jan 12 2022 6:22pm
Stand Easy
Andy K wrote:
https://www.gap-diagnostic.com/avada_faq/how-to-activate-the-timed-climate-park-heat/
Sadly not Big Cry
Post #620882 Wed Jan 12 2022 9:05pm
Stand Easy
riverblanche wrote:
Hi,
Thanks for the info but I'm a technofobe when it comes to software, wouldn't know where to start Embarassed
Post #620883 Wed Jan 12 2022 9:07pm
