Home > General > FBH is mine functioning ?
Stand Easy
So I've established my FBH is functioning, it's below 4 deg here and as got out of the car I could here it running along with an odd smell, the exhaust pipe from it was hot and the air intake seemed to be functioning. There doesn't appear to be any timing options in the menu for it though so I need to look into the various options for this or a remote blipper perhaps, any pointers as to what to do regarding this? Bow down
Post #620911 Thu Jan 13 2022 7:34pm
There are more remote start options than you would believe !
You can text your car to start the heater. Good if your car is out of remote range. These are more expensive
And can be a pain to keep the sim alive
The best value for yours is probably the factory landrover option.
You fit a box in the boot and buy the CORRECT remote.
Though you probably need a gap iid. Humm
Post #620913 Thu Jan 13 2022 7:49pm
riverblanche
Hi,
I had a "discostick" remote which uses the 3rb button on the remote to start the FBH via the lights, it worked very well and was easy to fit they do come up for sale now and again, but as said you do need to be in key remote range to operate it
they look like this from over on D3
https://www.disco3.co.uk/forum/sold-3rd-bu...39755.html Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #620918 Thu Jan 13 2022 9:13pm
Stand Easy
I'll look to get the timed software update as a remote is probably not needed. I can't help but think what is the point of the FBH if it cant be switched on prior to starting the vehicle as normal Question
Post #620981 Sat Jan 15 2022 6:41pm
The point is it keeps the engine upto temperature, for efficiently and reliability
Post #620982 Sat Jan 15 2022 7:02pm
riverblanche
Stand Easy wrote:
Assuming this is the FBH then yes I have one Rolling with laughter
Hi,
dont know if this will affect the running Question
but where does the air intake come from and does it have the black plastic "filter" box on it, looked at some of my pics and the intake is above the exhaust tube.
Post #621127 Thu Jan 20 2022 3:55pm
Here's the manual for the heater:
https://www.rrsport.co.uk/gallery/albums/u...en-WEB.pdf
Hopefully that will help. 2012 SDV6 - it's missing a couple of cylinders
Post #621150 Fri Jan 21 2022 10:16am
