![]() | Home > Technical > Battery out put on a range rover sport HSE 2006 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
There is a 15A fuse under the floor where the jack is.
Yes 2010 is different.
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 240 ![]() ![]() ![]() |
Great i will use this left tow side then and connect some lights using the ctek connectors, Do you know if i can utilise the right towing connector? I.e a live feed or is that just for the lights? |
Black. Just for road lights |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
For the facelift if it's any help, might need to view in "my gallery" to get clearer image.
Thanks Col, That shows in detail. So this ctek connector must be wired to pin 4 live and ground giving you opportunity to charge via charger but i want to utilise it by modifying a ctek cable to fit a cigarette socket then i can put something like this off amazon on it and have a charging station at the rear constantly powered and have some low power leds on it aswell is my plan.
