Home > Technical > Battery out put on a range rover sport HSE 2006
There is a 15A fuse under the floor where the jack is.
Or use pin4 in white tow socket
Post #623647 Mon Apr 18 2022 4:53am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Is Pin 4 on a 30a fuse mate and does it stay live when car is locked? I looking for an easy and safe way of quickly plugging in a few low powered lights to put around my vehicle when camping, I have thought about using my tow bar connecter and wiring it to a double or triple cigarette socket so i have a few quick connections, I looked under my jack and couldnt find any fuse box, I have a 2010 rrs if thats different?
Post #623657 Mon Apr 18 2022 1:48pm
Yes 2010 is different.
Yes pin 4 is live all the time.
pin 3 earth
Post #623662 Mon Apr 18 2022 3:40pm
jases4x4
Great i will use this left tow side then and connect some lights using the ctek connectors, Do you know if i can utilise the right towing connector? I.e a live feed or is that just for the lights?
Post #623663 Mon Apr 18 2022 4:04pm
Black. Just for road lights
Post #623664 Mon Apr 18 2022 5:50pm
For the facelift if it's any help, might need to view in "my gallery" to get clearer image.
Post #623667 Mon Apr 18 2022 8:31pm
jases4x4
Thanks Col, That shows in detail. So this ctek connector must be wired to pin 4 live and ground giving you opportunity to charge via charger but i want to utilise it by modifying a ctek cable to fit a cigarette socket then i can put something like this off amazon on it and have a charging station at the rear constantly powered and have some low power leds on it aswell is my plan.
Post #623668 Mon Apr 18 2022 8:42pm
