Home > Technical > Battery out put on a range rover sport HSE 2006
Joe Hankey
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Dose anyone know the battery out put on a range rover sport 2.7 hse 2006. So I can get an inline fuse fitted. In amps please. This is so I can put a in line fuse protection for my battery.
Post #619815 Tue Dec 07 2021 10:02pm
Might be worth being a little more specific in what you actually want the fuse to protect.
This would be the spec. of the original battery fitted.
Post #619816 Tue Dec 07 2021 10:48pm
Devon Z
Re: Battery out put on a range rover sport HSE 2006
That’s gonna one big fuse holder 😳 might want to look at a thermal cut off? Though I’m no expert 😁 Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #619823 Wed Dec 08 2021 12:38pm
It's more to do with the thickness of the cables between the battery and Anderson connector.
If you want to use it for jump starting, then I suggest 250A
Post #619824 Wed Dec 08 2021 1:02pm
Joe Hankey
Yes it's for the Anderson connectors
Post #619825 Wed Dec 08 2021 1:09pm
You may want something like this to hold the fuse in
They are the same, just different prices
https://www.ebay.co.uk/itm/384526945584?ha...Sw6QFhnpku
https://www.ebay.co.uk/itm/163971248913?ha...SwYZJd5UYA
This is in New condition and cheaper :
https://www.ebay.co.uk/itm/353797557487?ha...SwOldhnM9J
and buy a fuse for it. Search for mega fuse 250A
oh, here is all in one sale
https://www.ebay.co.uk/itm/313673561330?_t...BMhKz1orNf
another example
https://www.ebay.co.uk/itm/363428716263?ep...Swx4ZgwK1U
Post #619826 Wed Dec 08 2021 1:13pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
This has me thinking about a power connection on my roof rack(waterproof obviously) instead of numerous cables going to battery, I want to put a few different light bars etc on the front and back of the roof rack.
Does anyone have anything in mind that would work? So only having 2 cables to the battery down the windscreen pillar then some sort of junction box/fuse box i could then feed from for numerous 12v connections?
Post #619827 Wed Dec 08 2021 1:23pm
aaronjb
https://www.12voltplanet.co.uk/ or http://www.autoelectricsupplies.co.uk/ will have what you need for that - put a high value fuse (just lower than the rating of the cable, which should be higher than the rating of your total load - they have calculators) by the battery, run a feed to the rear and then fit one of the standard blade fuse fuse boxes to fuse individual feeds. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619831 Wed Dec 08 2021 4:12pm
jases4x4
Is there a power feed already in the boot area i could use? I know theres a cigarette socket in boot but not sure on how much the load can take, i also have a towing connection, Could this feed be used or tee off it with a junction box?
Post #619835 Wed Dec 08 2021 6:02pm
Joe Hankey
Battery output
That's not my job. You need a auto electrician.
Post #619836 Wed Dec 08 2021 6:14pm
There is 30A available in the rear left (tow bar )
Post #619837 Wed Dec 08 2021 6:20pm
jases4x4
Thanks Andy, Is this the power feed to the towing socket, And do you think 30a would be enough to power a few light bars? This could save me having to feed new cables from the battery if so. Cheers
Post #619838 Wed Dec 08 2021 7:04pm
Easy enough to calculate, just add wattage of the bulbs together and divide by 12 (volts) will give you the total amp output, if my calculations are right 30 amps should give you around 360 watts. It is however a long time ago since I last went to school. Laughing
Post #619842 Wed Dec 08 2021 7:52pm
Yes the tow feed. Green wire with some stripe.
30a plenty for lights.
And Cols formula is correct
Post #619844 Wed Dec 08 2021 8:33pm
jases4x4
Hi Andy/Col
Im looking to add some lights now to my set up for when im camping, Something i can just plug into the tow socket like the ctek charging connector Or is there a fuse board at the back where i can plug one of those double connection fuses into and then wire from there to my lights?
Is the towing socket connection constantly live aswell?
Post #623643 Sun Apr 17 2022 10:25pm
