![]() | Home > General > Issue with doors locking |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 222 ![]() ![]() ![]() |
The central locking door actuators , common problem I've had them all replaced over the last 2 years. |
The beeping is probably a faulty bonnet catch , I've had that replaced as well. |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
yeah, if the bonnet catch is not closed properly, it will let you know on the dash display.
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 ![]() ![]() ![]() |
Thanks for the replies guys.
Try locking the car, and letting it beep at you, then try all the doors, and both tailgates, to see which one isn't locked. Or I think you can do the same with the interior dash lock button. That way you will know which one is faulty.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
To change the lock motor, it isn't an auto elec Job.
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
I had this problem, caused by the lower tailgate latch.
