Home > General > Issue with doors locking |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
The central locking door actuators , common problem I've had them all replaced over the last 2 years. |
Sat Nov 20 2021 12:20pm |
The beeping is probably a faulty bonnet catch , I've had that replaced as well. |
Sat Nov 20 2021 2:24pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
yeah, if the bonnet catch is not closed properly, it will let you know on the dash display.
Sat Nov 20 2021 2:42pm |
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 |
Thanks for the replies guys.
Sun Nov 21 2021 9:36am |
Try locking the car, and letting it beep at you, then try all the doors, and both tailgates, to see which one isn't locked. Or I think you can do the same with the interior dash lock button. That way you will know which one is faulty.
Sun Nov 21 2021 9:42am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
To change the lock motor, it isn't an auto elec Job.
Sun Nov 21 2021 11:54am |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 80 |
I had this problem, caused by the lower tailgate latch.
Mon Nov 22 2021 11:35am |
