![]() | Home > General > Issue with doors locking |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 ![]() ![]() ![]() |
The central locking door actuators , common problem I've had them all replaced over the last 2 years. |
The beeping is probably a faulty bonnet catch , I've had that replaced as well. |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
yeah, if the bonnet catch is not closed properly, it will let you know on the dash display.
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 ![]() ![]() ![]() |
Thanks for the replies guys.
Try locking the car, and letting it beep at you, then try all the doors, and both tailgates, to see which one isn't locked. Or I think you can do the same with the interior dash lock button. That way you will know which one is faulty.
To change the lock motor, it isn't an auto elec Job.
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
I had this problem, caused by the lower tailgate latch.
