![]() | Home > Technical > Performance Restriction - No Air leaks |
The service manual, she say:
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 781 ![]() ![]() ![]() |
There are 2 MAF sensors on the air filter box, and from memory had the same. Could it be that, worth asking. There is a part number on the MAF's and all I did was Google it and found one locally, less than £50 if I remember correctly. A couple of screws and a jubilee clip and all was good. |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Before you do anything else remove the MAP sensor from the manifold (one bolt) and pull it out. Check that the inside end of it is clean, as it can get very caked with sludge, and then it doesn't read the pressure correctly.
K!AN1 Member Since: 15 Jul 2021 Location: Reading Posts: 20 ![]() ![]() ![]() |
No, no other related codes, just the P006A-00 code.... |
Thanks you, will do this first! |
Thanks, next step after the MAP sensor clean! |
