Home > Technical > Performance Restriction - No Air leaks |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
The service manual, she say:
Fri Nov 19 2021 9:47am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
There are 2 MAF sensors on the air filter box, and from memory had the same. Could it be that, worth asking. There is a part number on the MAF's and all I did was Google it and found one locally, less than £50 if I remember correctly. A couple of screws and a jubilee clip and all was good. |
Fri Nov 19 2021 9:49am |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Before you do anything else remove the MAP sensor from the manifold (one bolt) and pull it out. Check that the inside end of it is clean, as it can get very caked with sludge, and then it doesn't read the pressure correctly.
Fri Nov 19 2021 3:13pm |
K!AN1 Member Since: 15 Jul 2021 Location: Reading Posts: 20 |
No, no other related codes, just the P006A-00 code.... |
Mon Nov 22 2021 10:51am |
Thanks you, will do this first! |
Mon Nov 22 2021 10:52am |
Thanks, next step after the MAP sensor clean! |
