Home > Wheels & Tyres > Tight tolerance mode Staffordshire
Grimble
I need my wheels aligning after having the steering arm replaced and will be fitting new tyres at the same time. Also need the steering wheel re-centred. Have been ringing around tyre places and none seem to know what tight tolerance mode is, which doesn't instil a lot of faith. Can anybody recommend somewhere near Stafford? RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #617522 Tue Sep 21 2021 9:49am
Could google alignmycar.co.uk and input postcode they should be able to list anyone with Hunter Equipment in your area.
Post #617523 Tue Sep 21 2021 10:02am
Many of the Hunter operators don't have the dongle to enter in to tight mode, sadly. It's a big cost for a relatively small number of potential customers. 2012 SDV6 - it's missing a couple of cylinders
Post #617532 Tue Sep 21 2021 2:57pm
knwatkins
You don't need to plug anything into the vehicle to enter TTM on the newer models.
Activation:
1. Gearbox in Park
2. Start the engine
3. Suspension in normal height
4. Open the driver's door
5. Press the brake pedal 3 times
6. Close the driver's door within 10 seconds of the first brake pedal press
If successful, the instrument cluster will emit two soft chimes after the driver's door is closed, to indicate the air suspension system is in TTM.
Deactivation:
Turn the engine off or drive the vehicle over 5 mph
The above may help if you chose to go somewhere that doesn't know about getting the vehicle into TTM. Once it's in TTM, it's just the same as aligning any other vehicle. The recommendation would always be to use an experienced operator with good quality (eg. Hunter) equipment, however. Kev
Post #617542 Tue Sep 21 2021 6:47pm
Tyrefitter
Most garages usually have a Snapon diagnostic machine,if they go into make/model then suspension,it is there tight tolerance mode. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #617553 Wed Sep 22 2021 5:01am
DrRob
Take it to Henshalls Engineering in Cheshire. Visitor from fullfatrr.com
Post #617556 Wed Sep 22 2021 7:07am
Grimble
Activation:
1. Gearbox in Park
2. Start the engine
Deactivation:
When you say 'newer models' mines one of the first L494, does it apply? RRS HSE Dynamic SDV6 2014
Post #617570 Wed Sep 22 2021 11:41am
knwatkins
Yes Kev
Post #617576 Wed Sep 22 2021 12:27pm
Grimble
Thanks for all the advice and replies.
Given that wheel alignment is not exactly an unusual activity, why is the information above not in the manual to pass on to whoever is doing the job?
After all, these vehicles are hardly ten a penny.
Or being cynical, is it a way of nudging you towards a dealer? RRS HSE Dynamic SDV6 2014
Post #617624 Thu Sep 23 2021 9:33am
knwatkins
Good point. It will be in the service manual but not the user manual/handbook. Probably because it's not a 'user function' I would imagine.
We're all allowed to be a bit cynical though Wink Kev
Post #617647 Thu Sep 23 2021 7:56pm
