![]() | Home > Wheels & Tyres > Tight tolerance mode Staffordshire |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
I need my wheels aligning after having the steering arm replaced and will be fitting new tyres at the same time. Also need the steering wheel re-centred. Have been ringing around tyre places and none seem to know what tight tolerance mode is, which doesn't instil a lot of faith. Can anybody recommend somewhere near Stafford? RRS HSE Dynamic SDV6 2014
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Could google alignmycar.co.uk and input postcode they should be able to list anyone with Hunter Equipment in your area.
You don't need to plug anything into the vehicle to enter TTM on the newer models.
Most garages usually have a Snapon diagnostic machine,if they go into make/model then suspension,it is there tight tolerance mode. Andy.
Take it to Henshalls Engineering in Cheshire. Visitor from fullfatrr.com
When you say 'newer models' mines one of the first L494, does it apply? RRS HSE Dynamic SDV6 2014 Nemo mortalium omnibus horus sapit |
Yes Kev
Thanks for all the advice and replies.
Good point. It will be in the service manual but not the user manual/handbook. Probably because it's not a 'user function' I would imagine.
