Home > Wheels & Tyres > Tight tolerance mode Staffordshire |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 |
I need my wheels aligning after having the steering arm replaced and will be fitting new tyres at the same time. Also need the steering wheel re-centred. Have been ringing around tyre places and none seem to know what tight tolerance mode is, which doesn't instil a lot of faith. Can anybody recommend somewhere near Stafford? RRS HSE Dynamic SDV6 2014
Tue Sep 21 2021 9:49am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5028 |
Could google alignmycar.co.uk and input postcode they should be able to list anyone with Hunter Equipment in your area.
Tue Sep 21 2021 10:02am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
You don't need to plug anything into the vehicle to enter TTM on the newer models.
Tue Sep 21 2021 6:47pm |
Most garages usually have a Snapon diagnostic machine,if they go into make/model then suspension,it is there tight tolerance mode. Andy.
Wed Sep 22 2021 5:01am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Take it to Henshalls Engineering in Cheshire. Visitor from fullfatrr.com
Wed Sep 22 2021 7:07am |
When you say 'newer models' mines one of the first L494, does it apply? RRS HSE Dynamic SDV6 2014 Nemo mortalium omnibus horus sapit |
Wed Sep 22 2021 11:41am |
Yes Kev
Wed Sep 22 2021 12:27pm |
Thanks for all the advice and replies.
Thu Sep 23 2021 9:33am |
Good point. It will be in the service manual but not the user manual/handbook. Probably because it's not a 'user function' I would imagine.
Thu Sep 23 2021 7:56pm |
