Home > General > 2013 L320 tailgate Strut |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
You need to remove tailgate interior trim panel to get access to the electrical connector.
Sat Aug 14 2021 9:36pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
I'd replace the ball joint too if you can - having just had struts replaced on ours and getting similar symptoms almost straight away new balls sorted it 2012 SDV6 HSE (technically its hers)
Mon Aug 16 2021 7:12pm |
Stavroskon Member Since: 02 Dec 2021 Location: Athens Posts: 7 |
Hello!! Yesterday I replaced two electrics struts !!!! You must remove the handle cover with flat knife , you must remove the 2 screws under this cover … then just unclip the plastic trim … you find the connectors inside lower panel ! The problem is that after this job my tailgate opens and close continuously.. press to open tailgate opens then close !!! My tail gate doesn’t stay open !!!! Any suggestions??? |
Fri Dec 03 2021 6:46am |
