![]() | Home > In Car Electronics > New member with common radio problem - help please |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
Something on the most/optical bus is dead or jamming it up.
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
I had a similar problem. Turned out to be a faulty amp. |
Paul_hst Member Since: 13 Jul 2021 Location: North Yorkshire Posts: 9 ![]() ![]() ![]() |
Thanks for the replies, seems strange how it also effects the sat nav & Tv, I am going to get a MOSt tester and check out the fibre optics |
Not really. It stops the network talking.
grimreaper Member Since: 18 Oct 2020 Location: Cheshire Posts: 18 ![]() ![]() ![]() |
Got the same problem screen works no dab no BT no rear cam no voice is the rear cam connected to the most ring? I connected my by pass loop to the bt and dab units in turn no luck cant find the ring fibre optics for the rear cam have noticed that most light comes on at rear of amp but then goes off is this possibly a faulty amp???
The camera isn’t on the most
May as well leave the loop fitted !
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Module No.2 is described as Radio Receiver Module which is the TMC module I think, No.3 is the RSE Module, not sure on the first one I think it may be the TV Tuner.
2 Traffic info (waste of space)
Thanks for all the feedback, have taken the rear entertainment out of the loop, now have radio, sat nav, 4 x 4screen and front tv (sound only at moment) Held the fibre optic from the rse unit to the blue tooth and all came back on. |
So RSE unit then.
