Home > In Car Electronics > New member with common radio problem - help please
Paul_hst
Hi, just joined the Forum and only had my Sport HSE TDV8 (57 plate) a few weeks, however it seams to have the problem i have seen so many times on here but with no definitive answer. The entertainment/navigation screen started to loose some of the buttons, TV, Rear Screens & DVD, they greyed out so you couldn't touch them at the same time the sound went from the radio. Now all I have a is the Land Rover logo on screen and no sound from radio or CD but power to the unit. I have checked all fuses and there is power into the amp. I see some people mention the Bluetooth but not sure where that is. Ant advice would be most welcome.
Post #615744 Wed Jul 14 2021 3:15pm
Something on the most/optical bus is dead or jamming it up.
The BT is in the boot on drivers side
Behind trim
Post #615745 Wed Jul 14 2021 3:35pm
idi
I had a similar problem. Turned out to be a faulty amp.
Post #615757 Wed Jul 14 2021 9:26pm
Paul_hst
Thanks for the replies, seems strange how it also effects the sat nav & Tv, I am going to get a MOSt tester and check out the fibre optics
Post #615761 Wed Jul 14 2021 9:47pm
Not really. It stops the network talking.
It doesn’t pass messages on in the chain
Post #615768 Thu Jul 15 2021 7:17am
grimreaper
Got the same problem screen works no dab no BT no rear cam no voice is the rear cam connected to the most ring? I connected my by pass loop to the bt and dab units in turn no luck cant find the ring fibre optics for the rear cam have noticed that most light comes on at rear of amp but then goes off is this possibly a faulty amp???
Mark.
Post #615791 Thu Jul 15 2021 9:12pm
The camera isn’t on the most
The red light will go off after a few seconds
Post #615796 Thu Jul 15 2021 10:21pm
Paul_hst
I received a fibre optic loop to try to sort my issues and had a signal at unit 3 on the pic but no further, could someone identify the 3 units on the pic, i also have a dvd changer close by and units under both front seats, Sat Nav & Amp, i think. I did try the loop and and had sound and image for a few minutes. so many wires.....thanks
Post #615831 Fri Jul 16 2021 4:54pm
May as well leave the loop fitted !
And see what doesn’t work !
Post #615832 Fri Jul 16 2021 5:12pm
Module No.2 is described as Radio Receiver Module which is the TMC module I think, No.3 is the RSE Module, not sure on the first one I think it may be the TV Tuner.
Post #615842 Sat Jul 17 2021 4:11am
2 Traffic info (waste of space)
3. RSE = rear seat entertainment
Post #615843 Sat Jul 17 2021 9:28am
Paul_hst
Thanks for all the feedback, have taken the rear entertainment out of the loop, now have radio, sat nav, 4 x 4screen and front tv (sound only at moment) Held the fibre optic from the rse unit to the blue tooth and all came back on.
Post #615854 Sat Jul 17 2021 4:02pm
So RSE unit then.
First check it has power to it
Post #615855 Sat Jul 17 2021 4:43pm
