![]() | Home > General > 2010 tdv8 air suspension strut replacement |
Very easy to change. One big bolt at the bottom, 3 little bolts at the top. 30 minute job. Kev
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
If it's got the dynamic dampers they're not cheap and one should replace dampers as an axle pair.
rrsade Member Since: 15 Sep 2020 Location: swansea Posts: 13 ![]() ![]() ![]() |
Thanks guys,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
That price per strut is because they come in a pretty box with Land Rover on it, go O.E Aftermarket in a plain box and you will get a pair for that price.
If you have the adaptive dampers, it's part number LR052867 you need.
Kev, don't know where the struts are actualy made, but although BWI is O.E. BWI is a Chinese company they bought that part of Delphi about 10 years ago, hopefully they are better quality than the usual Chinese stuff though. |
Yes, I remember that from when I was looking at them a few months ago Col in case I ever need to replace them on the L405.
Use www.advancedfactors.co.uk
I was going to suggest that Rob but for the same Advanced are £103.51 more expensive per strut than lrseries.com |
Thanks for that guys, will go for the bwi ones if the same as original delphi one i got on now,
Yes. Dampers should always be changed as an axle pair. If you have a brand new damper on one side and tired old one on the other side, you'll get some potentially unpleasant ride/handling characteristics. And that could lead to an accident. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
^^^^agreed |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
I was under the impression that the air spring can be separated from the damper and can be replaced individually. I don't know if that is a sensible approach, how much additional work it is involved or how much can be saved. Those struts are bloody expensive. |
The damper is the expensive part of the strut. 2012 SDV6 - it's missing a couple of cylinders
