Home > General > 2010 tdv8 air suspension strut replacement |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Very easy to change. One big bolt at the bottom, 3 little bolts at the top. 30 minute job. Kev
Fri Jul 09 2021 6:59am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
If it's got the dynamic dampers they're not cheap and one should replace dampers as an axle pair.
Fri Jul 09 2021 7:03am |
rrsade Member Since: 14 Sep 2020 Location: swansea Posts: 13 |
Thanks guys,
Fri Jul 09 2021 8:25am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
That price per strut is because they come in a pretty box with Land Rover on it, go O.E Aftermarket in a plain box and you will get a pair for that price.
Fri Jul 09 2021 8:47am |
If you have the adaptive dampers, it's part number LR052867 you need.
Fri Jul 09 2021 9:21am |
Kev, don't know where the struts are actualy made, but although BWI is O.E. BWI is a Chinese company they bought that part of Delphi about 10 years ago, hopefully they are better quality than the usual Chinese stuff though.
Fri Jul 09 2021 9:41am |
Yes, I remember that from when I was looking at them a few months ago Col in case I ever need to replace them on the L405.
Fri Jul 09 2021 9:50am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Use www.advancedfactors.co.uk
Fri Jul 09 2021 9:55am |
I was going to suggest that Rob but for the same Advanced are £103.51 more expensive per strut than lrseries.com Even with the forum discount, that's a hell of a lot more expensive.
Fri Jul 09 2021 10:30am |
Thanks for that guys, will go for the bwi ones if the same as original delphi one i got on now,
Fri Jul 09 2021 10:36am |
Yes. Dampers should always be changed as an axle pair. If you have a brand new damper on one side and tired old one on the other side, you'll get some potentially unpleasant ride/handling characteristics. And that could lead to an accident. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Jul 09 2021 1:32pm |
^^^^agreed Kev
Fri Jul 09 2021 2:13pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I was under the impression that the air spring can be separated from the damper and can be replaced individually. I don't know if that is a sensible approach, how much additional work it is involved or how much can be saved. Those struts are bloody expensive. |
Fri Jul 09 2021 2:40pm |
The damper is the expensive part of the strut. 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 09 2021 10:10pm |
