Home > General > Car alarm going off and indicating on dashboard bonnet open! |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 |
A very common fault , mine did the same new alarm sensor required bonnet area I had my indi replace mine as its service was due but apparently it is an easy fix it you want to replace it yourself. |
Sat May 08 2021 5:38pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
I would hazard a guess and say the bonnet switch is faulty,,, or mal- adjusted. Disconnect it and link the connector out with a paper clip or something similar and see if the fault disappears when you set the alarm. I believe it's a known problem on other models. 2010 RRS, TDV8
Sat May 08 2021 5:44pm |
Benrrs2021 Member Since: 03 May 2021 Location: Morecambe Posts: 14 |
I recently had this issue too. Immediately jumped to the conclusion the latch sensor was duff but infact a little lube of the latches themselves sorted it for me. One side just wasnt quite latching back correctly and i assume the sensor wasnt making. |
Sun May 09 2021 10:41am |
rabcnesbit Member Since: 29 Jun 2010 Location: London Posts: 95 |
Many thanks all for your replies and advice. Much appreciated! RRS 2.7 TDV HSE MY07 |
Sun May 09 2021 3:24pm |
