Home > General > Car alarm going off and indicating on dashboard bonnet open!
rabcnesbit
A few days ago, drove the car Evoque (MY 2012) to the store and coming back out found the alarm goone off, which I had to stop by disarming the alarm via the key. Checking the warning on the dashboard, it states "bonnet open". Which threw me as the bonnet had not been touched since the last time it was at the garage many months ago! Anyway, opened the bonnet and slammed it shut (to ensure its definitely shut). However, when I armed the car again, a few minutes later, the alarm went off and showing the same message "bonnet open". Any ideas what could be the problem? Thank you RRS 2.7 TDV HSE MY07
Post #613422 Sat May 08 2021 2:07pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
A very common fault , mine did the same new alarm sensor required bonnet area I had my indi replace mine as its service was due but apparently it is an easy fix it you want to replace it yourself.
Post #613437 Sat May 08 2021 5:38pm
gogsy1956
I would hazard a guess and say the bonnet switch is faulty,,, or mal- adjusted. Disconnect it and link the connector out with a paper clip or something similar and see if the fault disappears when you set the alarm. I believe it's a known problem on other models. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #613438 Sat May 08 2021 5:44pm
Benrrs2021
I recently had this issue too. Immediately jumped to the conclusion the latch sensor was duff but infact a little lube of the latches themselves sorted it for me. One side just wasnt quite latching back correctly and i assume the sensor wasnt making.
Post #613453 Sun May 09 2021 10:41am
rabcnesbit
Many thanks all for your replies and advice. Much appreciated! Thumbs Up RRS 2.7 TDV HSE MY07
Post #613456 Sun May 09 2021 3:24pm
