Home > General (L494) > SDV6 timing chain/belt replacement - how often?
Page 1 of 3 123>
jamesgarbett
Mileage or age
Post #613019 Tue Apr 27 2021 9:26am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi had both changed at 62000 on my 2013 RRS L320 HSE - Cam belt and belt for high pressure fuel pump at back of engine.
Post #613023 Tue Apr 27 2021 12:02pm
SC247
They recomend every 7 years or 112K miles
Post #613024 Tue Apr 27 2021 12:06pm
jamesgarbett
Thanks both
Post #613025 Tue Apr 27 2021 12:08pm
Worth noting that it's a "whichever comes first" requirement. So a low mileage engine will still need the belts doing at 7 years, and a high mileage one might need them doing sooner as it will hit the mileage limit sooner. 2012 SDV6 - it's missing a couple of cylinders
Post #613028 Tue Apr 27 2021 2:05pm
jamesgarbett
Post #613037 Tue Apr 27 2021 5:51pm
pjbracer1
Yep its 84months or 112K miles
Recommended Services(Based on the age and mileage of your vehicle)
96,000Mls/72 Months Service
Plug - oil drain
Element - air cleaner
Filter - engine oil - element
Filter - odour and particles
Filter - fuel
Screen wash
3+ promotional oil
£560.07
Or
112,000Mls/84 Months Service
Plug - oil drain
Bolt - hex.head
Gasket - cover
Belt - timing
Kit - inj pump belt
Bolt and washer - hex.head
Screen wash
3+ promotional oil
£1,124.50
Ive just booked the 84Month at Guy Salmon Portsmouth! Tried to book with Hendy Southampton but get no email replies or no call backs, Also they dont appear on the LR online service booking portal so maybe they dont want service business!
Who knows mine is low mileage but it 7yrs now so thought it best to get the belts down with LR for the history btu also if there are any arguments firther down the line for things like the crankshaft.
Dont know why it needs screenwash!
https://osh.landrover.com/service-history check your last service here
My last one was the 60K mileage service but as last year nothing was possible ive just skipped a minor as It hardly did any miles and coudlnt be done last year, there will be loads of cars with a blip in the history and the MFR will have to respect that also.
Maintenance
Oil Change £221.85
Brake Fluid Change £53.46
Front Brake Pads and Discs £636.27
Rear Brake Pads and Discs £418.79
Front Brake Pads £370.57
Rear Brake Pads/Shoes £198.65
Replace Front Wiper Blades (Pair) £59.65
Rear Windscreen Wiper £38.98
Replace Battery £306.88
The above prices are quite high but for the likes of the oil change price isnt actually that bad considering a stamp in the book, and the cost of the oil, Battery price is steep when the battery only costs abotu £120
Courtesy car costs £30 per hire not per day but are like rocking horse poo so ive just opted for her indoors giving me a lift there and back as there is little wait time I booked to day for the service on thursday as the guy said most people want a courtesy car! Due to the amount of work he said it might be ready by the end of the day but might need it until the next day ,(just hope its not the rookie working on it!) Im gonna quiz them on the crankshaft issue if I can to see what they say.
I could use an Indy for this yes and probably will for other works like brakes and the likes but just for the engine issue potential I figure LR are more likely to offer good will if they have been the only ones who touched it.
Merc were the same my Amg need some work and they coverd 60% of the cost for a gearbox module that failed which was fair considering it was over 5yrs and just out of extended warranty. If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #613532 Tue May 11 2021 6:12pm
Kitchenfitter
So my RRS Dynamic is 7 yrs old reg 01/12/2015 and a 2016 Build.
It has approx 50k on the clock
Should I get the belts and a service done? ( oil and filter done sep2021)
If so what should be inc
My local indy has quoted £1276.93 for this but need clarify what it incldes RRS HSE DYNAMIC 2015 ODESSEY RED
Post #622558 Mon Mar 07 2022 6:51pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Mines similar, 7 year old in July so assume it needs the service with belts changing. Also need this service to keep the warranty valid as they say must be serviced to manufacturers specification. Had no quotes as yet but would be interested in a ball park figure so I don’t get ripped off.
Post #622565 Mon Mar 07 2022 9:43pm
Red Arrow
Yes 7 years old belts need done , ours has 76k and just had the belts done @ MMP - Dundee, Disco Mikey Thumbs Up
Top guy and way cheaper than the dealer Thumbs Up
Post #622570 Tue Mar 08 2022 12:17am
^ as others said, 7yrs/112Kmiles
see the maintenance check sheet: https://www.rrsport.co.uk/gallery/albums/u...0miles.pdf --
Post #622573 Tue Mar 08 2022 6:30am
Kitchenfitter
Is that check sheet what has to be done ?
Might send it to Indy Garage if so RRS HSE DYNAMIC 2015 ODESSEY RED
Post #622574 Tue Mar 08 2022 8:06am
Kot
Kitchenfitter
Use the link input your vin, it shows your service requirement schedule for your Car.
Select TAB servicing schedule, select service Type, select service you want and select Print or Submit to view.
Post #622582 Tue Mar 08 2022 10:43am
SC247
Had mine done at https://www.ovalautos.com/
£588 both belts inc vat same day
Post #622586 Tue Mar 08 2022 12:44pm
gtr_skyline
Mine will be booked in in May 2022 for the timing belt change and service - 35k miles, 7 years old in Sept 22. Sadly will go down the LR dealer route (Watford) as they will work on any warranty related items - had a great interim oil change at Langley 4x4 but sadly they can't process warranty claims otherwise indy all the way.
Prashan MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #622588 Tue Mar 08 2022 1:53pm
Page 1 of 3 123>
