Home > General (L494) > SDV6 timing chain/belt replacement - how often?
Page 2 of 3 <123>
What warranty are you using? Even Land Rover's extended warranty can be used at indies. You don't have to use the main dealer. 2012 SDV6 - it's missing a couple of cylinders
Post #622626 Wed Mar 09 2022 12:07am
gtr_skyline
Hi - yes, its the LR warranty, When I spoke to one of Roy's team at Langley 4 x 4, they were not sure if it would cover all the labour costs - would cover parts.
I will check again with Roy directly though - thanks for the prompt.
Prashan MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #622642 Wed Mar 09 2022 12:52pm
Kitchenfitter
So should i just have a vsic service and belts/tensioners etc changed as only done 50kmiles ? RRS HSE DYNAMIC 2015 ODESSEY RED
Post #622652 Wed Mar 09 2022 7:38pm
Lindab
Kitchenfitter, Mileage or time as rubber perishes. My car had belts, g/box flush & transfer box oil done at around 13000 miles. Luckily I stay in same town as Disco Mikey. I actually had them done a year early. Car not used much & a bit OCD regarding my cars, but better safe than sorry Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #622659 Wed Mar 09 2022 8:15pm
Kitchenfitter
Going to get belts done with service asap. Also picking up new Sos back up battery as get warning consatantly that sos functionality also will ask garage to check compresssor filyers as when car is put into access mode it goes into high mode and i have to keep pressi g access mode til it gives up fighting me lol
Any other advice what i should get done is appriciared
As well as any local indy to Coventry RRS HSE DYNAMIC 2015 ODESSEY RED
Post #623407 Wed Apr 06 2022 2:56pm
thdxb08
I had the same fault on my RANGE ROVER SPORT 2015 The new part has been modified from the original design with a hole drilled into the silencer. The silencer gets clogged up over time not allowing the air out to lower the car to access height.
(Suspension Air Supply Unit Exhaust Valve Fails To Vent).
See TECHNICAL BULLETIN LTB00793NAS3 23 AUG 2016
https://static.nhtsa.gov/odi/tsbs/2016/SB-10097249-1020.pdf
I replace the SUSPENSION COMPRESSOR SILENCER part No. LR088858 very easy to replace, take about 5 minutes.
Make sure the car is in the access lower position first before replacing the silencer.
To access the silencer which is under the spare wheel, undo the chrome clips holding the top cover of the compressor then using a 17mm.spanner undo the silencer.
Install the New silencer and Torque: 2.5Nm
Replace the cover to the compressor housing using 19 chrome clips - see pictures
Link below for ordering Compressor Silencer £6 approx
https://www.lrparts.net/lr088858-silencer-...-l494.html
Post #624599 Wed Jun 01 2022 3:30pm
Kitchenfitter
Thank you for info.
Still waiting to get car back from garage as timing kit was on back order to 30/5 but never showed now saying 16/6 !
So car at garage with no bt on 😵‍💫
Will.be selling it when I get it back as bought a classic SL320cab RRS HSE DYNAMIC 2015 ODESSEY RED
Post #624600 Wed Jun 01 2022 5:20pm
Kitchenfitter
Post #624601 Wed Jun 01 2022 5:20pm
Skyline
Lovely..SNAP - plan to use this as a daily too...just had the wiring harness and throttle body done
 MY23, 3.0 P440e PHEV AB, Carparthian Grey, Deep Garnett interior
Post #624656 Mon Jun 06 2022 11:03am
Deep92
timing belt on back order too for us.
Post #624680 Tue Jun 07 2022 5:12pm
Kitchenfitter
Nice motor 👌 RRS HSE DYNAMIC 2015 ODESSEY RED
Post #624682 Tue Jun 07 2022 6:21pm
Kitchenfitter
[quote="Deep92"]timing belt on back order too for us.[/quote
Bloody nightmare as I like to sell it now I have The SL320] RRS HSE DYNAMIC 2015 ODESSEY RED
Post #624683 Tue Jun 07 2022 6:22pm
Kitchenfitter
So timng kit that was on back order and due in totay has now been put off until 27th LR are a complete nightmare
Will be nearly 2 months without the car RRS HSE DYNAMIC 2015 ODESSEY RED
Post #624830 Thu Jun 16 2022 3:57pm
Disco_Mikey
We've had the main dealer on the phone asking if we have any Gen 2 belt kits on the shelf
The answer was no (I do, but I'm keeping them for my own customers Laughing ) but it's a little concerning that service items are unavailable Shocked
Post #624835 Thu Jun 16 2022 8:11pm
Kitchenfitter
Its a mare. But will have to wait as want correct belt kit fitting.
I will then have the chance to se it knowing all is good for new owner.
Ps appriciate the previous help from eveyone on here RRS HSE DYNAMIC 2015 ODESSEY RED
Post #624836 Thu Jun 16 2022 8:31pm
Page 2 of 3 <123>
