Home > General > DRL For L320 Autobiography
Page 2 of 3 <123>
Dave B
No, they are pure DRLs, I have no fog lights.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #610552 Wed Feb 24 2021 6:32pm
Autobiography1969
So does anyone have the factory DRL's fitted?
And if so how do you find them?
The powerfulUK ones that replace the fog lights and do
both functions are very nice too, but just wanted the factory look..
These would be my choice, and may still be at a later date,
can never have too much light..
https://www.powerfuluk.com/vehicles/range-...ype-2.html ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #610567 Wed Feb 24 2021 9:09pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
They do look nice and quite easy to install, I would like these to replace fogs and have the factory drl led strip in the lower grill section that would give plenty of light 😃
Post #610571 Wed Feb 24 2021 9:18pm
jases4x4
So i have bought these as they have 4 leds which hopefully will match the standard factory look, These are very bright i temporarily wired them to my battery, these definitely need to go off when headlights come on as they’re too bright for night driving. Does anyone know if these can be dimmed using the control boards you can buy to wire drl to dipped beam so they then stay on but low like the signature led’s look?
Post #610911 Tue Mar 02 2021 8:15pm
Autobiography1969
Just wondering if anyone has these fitted?
Original ones not the aftermarket ones, VPLSV0065
Are they properly bright and visible from a all angles
or are they a waste of time?
Thank you,, ===========================================
Post #610914 Tue Mar 02 2021 8:30pm
RRSSDDUB
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
any updates on this thread - any pictures of completed ????
Post #612583 Mon Apr 12 2021 10:10pm
jases4x4
I ended up fitting the osram drl’s as these look better quality build and still have the 4 leds to keep the factory drl look. Also i have the 2in1 powerful uk fogs which are very similar to the signature leds in the headlights so help blend it all together imo, the picture doesnt look the best with iphone but you get the idea, My drl come on once opened the car like welcome lights and stay on until you lock the car, once dimmed lights are turned on then drl dim 50% the 2in1 leds come on with sidelights.
Post #612584 Mon Apr 12 2021 10:36pm
RRSSDDUB
thanks - they look really good and certainly bright enough to be be DRLs!!!!!
Post #612603 Tue Apr 13 2021 1:11pm
jases4x4
They’re and because they’re low enough i dont get anyone flashing to say they blind them but have the effect wanted still.
Post #612606 Tue Apr 13 2021 1:46pm
Taff814
United Kingdom 2005 Range Rover Sport TDV6 HSE Orkney Grey
I've bought the 2 in 1 fog/DRL set from Powerful for my 2005 RRS. If I ever get out of Saudi and get them fitted I'll put some pics up
Post #612986 Mon Apr 26 2021 3:01am
RRSSDDUB
Taff i have been looking at these ones also - does anybody know if on 2012 autobiography the fog light surrounds just pull off or is it a bumper off job?
How did your fitting go taff?
Post #613111 Fri Apr 30 2021 8:43am
If I remember correctly the bezels are just held in with spring clips and can be popped out, but you still need to remove bumper to change lamps as held in with three screws from the back.
Post #613114 Fri Apr 30 2021 9:42am
RRSSDDUB
thanks, I watched a guide that said for pre 2010 models the plastic trims pop out and the lights can be changed by wiggling them out with bumper on....not sure if it is the same for 2012 autobiography?
Post #613115 Fri Apr 30 2021 10:25am
Would have thought it was just as easy to take the bumper off, easy enough and not a long job.
Post #613117 Fri Apr 30 2021 10:44am
Taff814
Sadly I'm still in Saudi. Might get home this year to do them...or maybe not Rolling Eyes Rolling Eyes
Post #613118 Fri Apr 30 2021 11:22am
Page 2 of 3 <123>
