Home > General (L494) > Update L494 Climate controls from 2014 to 2016 Part No?
Karlp606
Just seen this on ebay
https://www.ebay.co.uk/itm/265777094067?va...aDEALw_wcB
Presume anything with them 2 part numbers
DPLA-18A802-DH
GPLA-18A802-DH
Will be plug and play?
Post #627690 Wed Oct 26 2022 10:28am
moonstone
https://www.rrsport.co.uk/forum/post627691.html#627691
Now available for sale on the above thread.
Post #627692 Wed Oct 26 2022 10:37am
Karlp606
Ah sorry just sourced a GPLA-18A802-DH on ebay for £48 Smile
Post #627693 Wed Oct 26 2022 10:52am
this was my upgrade: https://www.rrsport.co.uk/forum/topic57083.html
slight issue afterwards due to the software mismatch: the Sync function now doesn't work well Whistle --
Post #627694 Wed Oct 26 2022 10:55am
Karlp606
Cool Cool yeh saw that - dont really use the sync function much as the Mrs has her side on at about 29c and mine is about 21c lol.
Did you find a way to flash the ccf with GAP at all?
Post #627695 Wed Oct 26 2022 10:58am
The car is going in for an HVAC repair - according to them, one of the blend motors is not working properly.
They will try to update the software, will report back. --
Post #627704 Thu Oct 27 2022 2:41am
Montipora
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Hi everyone, First post.
I’ve just ordered one off eBay which came today, was advertised as GPLA-18A802-DH from a MY17 but the part number is HPLA-18A802-DC.
Does anyone know if this will work, or should I send it back?
Post #628148 Fri Nov 11 2022 5:53pm
Karlp606
Just checked that part number and it has the little square led screens within the 3 circlular heat knobs, but I think its from a L405.
I haven't seen anyone use this part yet but I can't see a problem as the L405 and l494 use the same HVAC system.
If youve already ordered it then give it a go but if it doesn't work then resell it on Ebay and but the GPLA part number.
PS You need the engine running when you test it, It won't work with just the ignition on.
Post #628165 Sat Nov 12 2022 9:55am
Montipora
Thanks Karlp606, yes when I scanned the qr code it came up L405. Think I’ll try it and see. I can always send it back as the seller did advertise it as GPLA.
It’s definitely 2017 and the buttons push in, so should work
Post #628174 Sat Nov 12 2022 6:26pm
Montipora
Just to update, this part number HPLA 18A802DC didn’t work for me, had no screen and error messages on dash, blind spot monitoring inactive, charging system faulty 🤷‍♂️
Post #628332 Fri Nov 18 2022 5:20pm
Karlp606
Send it back as faulty and purchase the GPLA part number.
Post #628344 Fri Nov 18 2022 10:21pm
Montipora
I sent back the wrong one and managed to get the right one off eBay for £60, all done. Decent simple upgrade
Post #628727 Wed Nov 30 2022 8:23pm
Karlp606
Bosh!
Post #628728 Wed Nov 30 2022 8:40pm
Car has been in the shop since Monday: they fitted the new blend motors, but cannot intialise them because of the software mismatch I see since the upgrade: https://www.rrsport.co.uk/forum/post611088.html#611088
It looks like I will have to go back to the original panel Neutral --
Post #628740 Thu Dec 01 2022 6:20am
