![]() | Home > General (L494) > Update L494 Climate controls from 2014 to 2016 Part No? |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 43 ![]() ![]() |
I think this has been available 65 plate onward not 17. I am not sure whether they would be compatible but might worth that a try |
moonstone Member Since: 07 Jan 2021 Location: Scotland Posts: 41 ![]() ![]() |
Looks like you're right. Any idea of the part number? 2017 was maybe when they brought in the better infotainment touchscreen? |
Drago Member Since: 23 Jun 2019 Location: Uk Posts: 64 ![]() ![]() |
You can try the link below, just need to select which one.
im also in the market so if you do find an answer please share. I was looking at some parts on ebay and it appears they are different but if you take yours off and have a look at connectors that might be one way of to find out.
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
GPLA18A802DH |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 180 ![]() ![]() ![]() |
I've done the very same in my 2014 Dynamic, you can use assembly DPLA-18A802-DH or GPLA-18A802-DH.
Perfect. Thanks guys. I've ordered one on ebay.
Exactly the same reason I did it, it makes life so much easier with the Android unit fitted! |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Are both of these numbers the updated version, one seems a lot cheaper than the other? Joined the X5 45e club 1994 Defender 90 300 tdi |
Yes, the DH suffix is the important part, I bought the GPLA version as it was available and the cheapest, works perfectly on my heated/cooled seats. |
All fitted. Plug and play as mentioned above.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 411 ![]() ![]() |
I can confirm PN GPLA-18A802-DH is the correct PN and this is a pretty easy fit, just rear heater control surround (2 *mm bolts)
We're trading in the car now and so I'm now selling this item. Will update with a link in the For Sale Section shortly. |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 273 ![]() |
Didnt know you can do this!
