![]() | Home > General > HDC Speed Control |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
yes, use - and + |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Remember that HDC has a speed above which it will not operate. I think it's 30mph from memory. So you need to be doing less than that when you turn it on. It'll tell you if you're too fast.
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
indeed 30mph and you have to be going downhill.... Range Rover Vogue ‘17 TDV6
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
Is the speed displayed on the cluster like the cruise control speed? |
georgien Member Since: 01 Mar 2018 Location: Mignault Posts: 19 ![]() ![]() |
Yes ! Nik
Not on the L320, I believe. 2012 SDV6 - it's missing a couple of cylinders
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
Seem to recall from memory each press of the plus or minus button changes speed in increments of about 0.3mph. It is a really good bit of kit though it can take a bit of getting used to. |
