Home > General > HDC Speed Control |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
yes, use - and + |
Tue Feb 09 2021 4:30pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
Remember that HDC has a speed above which it will not operate. I think it's 30mph from memory. So you need to be doing less than that when you turn it on. It'll tell you if you're too fast.
Tue Feb 09 2021 6:59pm |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
indeed 30mph and you have to be going downhill.... Range Rover Vogue ‘17 TDV6
Wed Feb 10 2021 10:04am |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
Is the speed displayed on the cluster like the cruise control speed? |
Wed Feb 10 2021 10:32am |
georgien Member Since: 28 Feb 2018 Location: Mignault Posts: 19 |
Yes ! Nik
Wed Feb 17 2021 11:00am |
Not on the L320, I believe. 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 17 2021 4:04pm |
Seem to recall from memory each press of the plus or minus button changes speed in increments of about 0.3mph. It is a really good bit of kit though it can take a bit of getting used to. |
Sat Feb 20 2021 11:34am |
