![]() | Home > Technical > Replacement Key Fob |
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
Hi Guys, I'm after a bit of advise, I've recently purchased another key for the RRS which was advertised as new and with it looking like new and still having its identification sticker down the chrome part I took a gamble on, when it turned up this morning I slipped the chrome side bar off and inside is a cut emergency key, so I take it its been an unused spare key and has been already programmed to a car at some point, so what I'm asking is can the keys be reprogrammed to a different vehicle as is, or do they need the transponder chip changing like the slot in keys (not key less entry) on Vauxhall's and other makes ?.
Just to finish this up, a second hand fob can be reprogrammed to a different vehicle but only the doors and starting part, the emergency stick it under the column part cannot, that's a program once transponder chip and would not work on the new vehicle.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1191 ![]() ![]() ![]() |
@RugHead, would you mind posting a link to where you bought this new fob? thanks mate --
Hi naks, they do both frequencies 315 & 433 MHz. |
thanks mate, I have found a generic fob case locally.
