Home > Technical > Replacement Key Fob
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Replacement Key Fob
Hi Guys, I'm after a bit of advise, I've recently purchased another key for the RRS which was advertised as new and with it looking like new and still having its identification sticker down the chrome part I took a gamble on, when it turned up this morning I slipped the chrome side bar off and inside is a cut emergency key, so I take it its been an unused spare key and has been already programmed to a car at some point, so what I'm asking is can the keys be reprogrammed to a different vehicle as is, or do they need the transponder chip changing like the slot in keys (not key less entry) on Vauxhall's and other makes ?.
I've been out and had a go at reprogramming it with the Gap Tool, but I think because its a MY 13, it came back with a failure and a message "This version of key module may need to be unlocked contact GAP", does anybody have any ideas, thanks in advance.
Dek
Post #609691 Mon Feb 08 2021 2:56pm
RugHead
Just to finish this up, a second hand fob can be reprogrammed to a different vehicle but only the doors and starting part, the emergency stick it under the column part cannot, that's a program once transponder chip and would not work on the new vehicle.
On another note, I purchased one of the updated fobs off of the bay, as in the pictures and with the help of Patrick at GAP, it programmed straight in to the vehicle, but just as a warning if any body is thinking of buying one, it is slightly bigger in size than the original chrome bar type fob, but works perfectly.
Post #610549 Wed Feb 24 2021 5:21pm
@RugHead, would you mind posting a link to where you bought this new fob? thanks mate --
Post #629505 Fri Dec 30 2022 1:38pm
RugHead
https://www.ebay.co.uk/itm/333268358763?mk...media=COPY
Post #629513 Fri Dec 30 2022 7:16pm
RugHead
Hi naks, they do both frequencies 315 & 433 MHz.
Post #629523 Sat Dec 31 2022 2:41pm
thanks mate, I have found a generic fob case locally.
will just swap out the internals Thumbs Up --
Post #629524 Sat Dec 31 2022 2:50pm
