Home > Maintenance & Modifications > Roof Rack Plugs?
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
Roof Rack Plugs?
Don't know if anyone can help but I need to know the part name/no of the small round black rubber roof rack plugs that fit along the black trim strip on the roof?
I have just found one missing on the passenger side of my car and that small hole left un-covered on the roof was the cause of the vibrating and banging noise I could hear at speed on the passenger side, which I have been trying to locate and has been driving me nuts for ages! Shocked
I have covered it now with some black electrical tape I had on board (noise gone Thumbs Up ) but if anyone can help me locate one of the proper plugs to do the job properly I would be very grateful. Pete
2011 SDV6 HSE - Owned since July 2020
1989 Range Rover Classic 3.5 Vogue Manual - sold
Post #609380 Sat Jan 30 2021 7:16pm
Do you mean these RZM500041 ? I also fitted some extra ones of the DBE500013 clip when I fitted roof rails as there was only one each end which might help make it a bit more secure rather than just three plastic plugs. You might find the stem part of the plug is still stuck in the threaded part in which case you will have to dig it out, although if needed you can actualy buy the threaded boss as well separately.
Co
Post #609382 Sat Jan 30 2021 9:38pm
PeteF74
Hi Col.
That's amazing thank you! that's exactly the part I need and now I have a number it should be easier to find. I'll have a look to see if the thread is still in the hole. I just hope that wherever that hole leads to, it drains because its been in the rain for goodness knows how long.
Hope all is well with you down in NZ.
Pete Pete
Post #609387 Sat Jan 30 2021 11:13pm
All good here, sweltering at the moment temp's low to mid 30's Cool
This is the threaded bit, screws into roof panel with sealer and blind internal thread so any water can't really go anywhere except out of drain channels.
Post #609388 Sat Jan 30 2021 11:25pm
PeteF74
Hi Col.
Very Jelous... it's brass monkeys here, absolutely freezing cold at the moment. Salt all over the road and driving today I had the heated seat on and steering wheel on.
Thanks for the info, The irony is I have had a quicker response from someone on the other side of the world than I would have had from ringing my local LR parts department 7 miles away! Laughing Laughing Pete
Post #609391 Sun Jan 31 2021 12:34am
Stevepd
Cheapest I found was
https://www.google.co.uk/aclk?sa=l&ai=...amp;adurl=
or there was one seller wantin £7 for one. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #609397 Sun Jan 31 2021 9:14am
