Home > Maintenance & Modifications > Roof Rack Plugs? |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 |
Don't know if anyone can help but I need to know the part name/no of the small round black rubber roof rack plugs that fit along the black trim strip on the roof?
Sat Jan 30 2021 6:16pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Do you mean these RZM500041 ? I also fitted some extra ones of the DBE500013 clip when I fitted roof rails as there was only one each end which might help make it a bit more secure rather than just three plastic plugs. You might find the stem part of the plug is still stuck in the threaded part in which case you will have to dig it out, although if needed you can actualy buy the threaded boss as well separately.
Sat Jan 30 2021 8:38pm |
Hi Col.
Sat Jan 30 2021 10:13pm |
All good here, sweltering at the moment temp's low to mid 30's
Sat Jan 30 2021 10:25pm |
Hi Col.
Sat Jan 30 2021 11:34pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Cheapest I found was
Sun Jan 31 2021 8:14am |
