![]() | Home > Maintenance & Modifications > Roof Rack Plugs? |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 ![]() ![]() ![]() |
Don't know if anyone can help but I need to know the part name/no of the small round black rubber roof rack plugs that fit along the black trim strip on the roof?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Do you mean these RZM500041 ? I also fitted some extra ones of the DBE500013 clip when I fitted roof rails as there was only one each end which might help make it a bit more secure rather than just three plastic plugs. You might find the stem part of the plug is still stuck in the threaded part in which case you will have to dig it out, although if needed you can actualy buy the threaded boss as well separately.
Hi Col.
All good here, sweltering at the moment temp's low to mid 30's |
Hi Col.
Cheapest I found was
