Home > General (L494) > Engine Oil Level Sensor system fault
chrisjsw
Hi all,
Getting the above message (Engine Oil Level Sensor system fault) and the Service menu/oil level says "Not available" - anyone experienced this before and is there a way to manually check the oil level (just to be safe) ?
Its off to indie for service in a couple of weeks so may need to bring it forward? That said, its not being used much these days with COVID so maybe it can wait?
Thanks.
Chris 2015 Range Rover Sport L494 HSE Dynamic
Works at an Indy in Herts
Post #609269 Wed Jan 27 2021 3:49pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
I had the same issue on mine and there is no other way of checking the oil level.
I had mine repaired on my L494 last month.
Luckily it was done under warranty.
Dealer had the car for 6 days and it was replaced on my 2017 L494 TDV6 by moving the front differential forward and removing the sump to replace the sender and wiring loom. Sump apparently can't be removed with the front differential in place
Glad I wasn't paying for it.
I can't believe that LR haven't fixed this issue as its been around for a long time.
They should have left a dip stick on the engine as a backup!
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #609283 Thu Jan 28 2021 12:12am
Coedlan
I’ve had this issue twice.
Repaired first time in the last months of manufacturers warranty
Second time, approx a year later, replaced by Landrover dealer under goodwill
Similarly, can’t imagine a more stupid system, with no backup dipstick.
So, say I’m going on a long journey and want to check the oil level before I go. Can i just do it, no, I’ve got to go for a drive, to get the engine up to operating temp, park up on level ground and then wait 20 minutes or so, before the system will give a reading. Crazy system
Luckily Rolling with laughter due to the oil dilution issue, I now change my oil so frequently I know exactly how much oil is in the sump
Post #609290 Thu Jan 28 2021 10:41am
Coedlan
Re: Engine Oil Level Sensor system fault
chrisjsw wrote:
Hi all,
Thanks.
Chris
Should’ve added, if you suck all the oil out (quite easy with the right kit) then refill, you know how much is in the engine. Not convenient, but the only way, as far as I know
Good luck
John
Post #609291 Thu Jan 28 2021 10:44am
JamieLC
I read on a post on here before that if you unlatch your bonnet, leave the driver door open then go into the service menu, select oil level and quickly hit cancel on the steering wheel as the gauge comes on it will give you a reading. I will try to find the post. 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #609294 Thu Jan 28 2021 11:24am
Isn't the move to no dipstick just an emissions thing? I guess other manufacturers are doing the same thing as it allows the engine to be a sealed environment with no nasties finding their way out via the dipstick.
I remember a car that told me it had a problem before it showed anywhere else by blowing the dipstick out of the pipe. Turned out to be a blocked crankcase ventilator pipe. A Peugeot, I think it was. Today, the first thing you'd know about it would be an EML light. 2012 SDV6 - it's missing a couple of cylinders
Post #609295 Thu Jan 28 2021 11:35am
chrisjsw
Thanks for the responses guys.
Oddly when I tried it this morning, no error and it gave me a reading.
I'll keep an eye on it.
Post #609300 Thu Jan 28 2021 12:59pm
gtr_skyline
Open bonnet, ignition on, service menu, oil level display, press (cruise) cancel twice quickly. MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #609536 Thu Feb 04 2021 12:25pm
Coedlan
So the work around will check the oil level cold?
In that situation, does the system compensate for the temperature behind low, or is the change in volume, hence level, insignificant?
If so, you’d wonder why Landrover want the level check to be when the engine is at operating temperature?
Post #609540 Thu Feb 04 2021 1:12pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Ii can check my oil level when the engine is cold. Just press start button without pressing brake pedal and you can access oil level. There is no difference to oil level when engine is cold or warm, always on max.[/i]
Post #612274 Mon Apr 05 2021 7:03am
Dave-t
Mine had it replaced by the dealer when I bought the car. Apparently it’s £60 part but up to about 14 hours of labour to change. Strange thing is, it seems to be fairly common on RRS but I never heard of it on Disco 4. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #612277 Mon Apr 05 2021 12:16pm
Barryp
The issue is that oil seeps into the wiring loom, once this happens, its sump off to replace the loom and they usually replace the ultrasonic oil level unit at the same time as its a relatively cheap part. Anyway that's what they did to mine, see my post above.
Regards
Post #612287 Mon Apr 05 2021 7:31pm
HampshireDefender
Thank you! Just tried exactly that and it does work.
Post #625404 Wed Jul 13 2022 6:16pm
