![]() | Home > General (L494) > Engine Oil Level Sensor system fault |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
I had the same issue on mine and there is no other way of checking the oil level.
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
I’ve had this issue twice.
Should’ve added, if you suck all the oil out (quite easy with the right kit) then refill, you know how much is in the engine. Not convenient, but the only way, as far as I know Good luck John |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 ![]() ![]() |
I read on a post on here before that if you unlatch your bonnet, leave the driver door open then go into the service menu, select oil level and quickly hit cancel on the steering wheel as the gauge comes on it will give you a reading. I will try to find the post. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 ![]() ![]() ![]() |
Isn't the move to no dipstick just an emissions thing? I guess other manufacturers are doing the same thing as it allows the engine to be a sealed environment with no nasties finding their way out via the dipstick.
chrisjsw Member Since: 10 Jul 2018 Location: Buckinghamshire Posts: 70 ![]() ![]() |
Thanks for the responses guys.
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 ![]() ![]() |
Open bonnet, ignition on, service menu, oil level display, press (cruise) cancel twice quickly. MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
So the work around will check the oil level cold?
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
Ii can check my oil level when the engine is cold. Just press start button without pressing brake pedal and you can access oil level. There is no difference to oil level when engine is cold or warm, always on max.[/i] |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Mine had it replaced by the dealer when I bought the car. Apparently it’s £60 part but up to about 14 hours of labour to change. Strange thing is, it seems to be fairly common on RRS but I never heard of it on Disco 4. Joined the X5 45e club
The issue is that oil seeps into the wiring loom, once this happens, its sump off to replace the loom and they usually replace the ultrasonic oil level unit at the same time as its a relatively cheap part. Anyway that's what they did to mine, see my post above.
HampshireDefender Member Since: 20 Feb 2022 Location: Fleet Posts: 1 ![]() ![]() |
Thank you! Just tried exactly that and it does work. |
