![]() | Home > Technical > Active control roll module |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
Base of A pillar, underneath the RLM |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 ![]() ![]() ![]() |
Thanks Mikey
Offside
Perfect thanks. Current cars
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
Does the instrument cluster need to be removed for it to be accessed? |
No |
I have taken the panel under the steering wheel off and the panel at the side of the accelerator and couldn't see it is it up high or down low? Current cars
Relatively low. Not sure i have a pic of its location on my phone. Its just, there... |
Thanks Mikey
Out of interest, what is the problem with the car? |
The car is reporting problems with the suspension which is putting it in limp mode, The computer puts out an error code that points to the Active roll control module or associated wiring.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Make sure the replacement module is configured for the TDV8 as they had two tunes in them, one for the TDV6 and V8 petrol and the other for the TDV8.
Do you know how to configure them? Current cars
