Home > Technical > Active control roll module |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
With a suitable diagnostic tool |
Tue Dec 29 2020 5:59pm |
As long as you don't say Snap on, or Autel |
Wed Dec 30 2020 6:24am |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 |
OK got the part and have fitted it in a manner.
Wed Dec 30 2020 7:33pm |
If there is no change, that suggests that the original module isn't faulty
Wed Dec 30 2020 8:58pm |
Mikey
Wed Dec 30 2020 9:48pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
What led you to believe the original module was faulty and not possibly one of the two accelerometers being the suspect.?
Wed Dec 30 2020 9:57pm |
Fault code came up on the computer and when I researched the meaning of the code there were 3 possible solutions. The first was the ACRM and the other two were wiring to the same. Easy to start with thecomponent. Current cars
Wed Dec 30 2020 11:00pm |
What codes did you have? |
Thu Dec 31 2020 6:48am |
U0434 Current cars
Thu Dec 31 2020 7:18am |
And codes from the other modules?
Thu Dec 31 2020 7:31am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Do you have any warning lights or dash messages while driving ? |
Thu Dec 31 2020 10:20am |
Suspension Fault
Thu Dec 31 2020 11:08am |
OK, but what fault codes? |
Thu Dec 31 2020 1:14pm |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
I currently have the same problem as you with the same message on the dashboard. I have replaced the ACR module with a brand new one from Land Rover and had it coded in etc and it didn't fix the issue.
Thu Dec 31 2020 1:25pm |
