![]() | Home > Technical > DSC light comes on when turning right. |
steering angle needs calibration probably
Could be an ABS sensor has been knocked when the wheels were changed. That would give it the willies in certain situations. 2012 SDV6 - it's missing a couple of cylinders
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 ![]() ![]() ![]() |
Thanks guys.
if you have an IID you can calibrate yourself |
I dont have one |
Think problem solved...
"Didn't think DSC would be so sensitive to tyre pressures"
36psi all round is a bit low at the back (or high at the front if you prefer). I'd put the pressures to standard (on the label on the driver's door) and then work from there. I tend to run my fronts a couple of psi higher than standard because I find the ATs I run are happier that way. With a pure road tyre, the pressures should work better if the relationship between front and rear pressures follows the standard. i.e. if you go up a couple at the front, go up a couple at the rear too. 2012 SDV6 - it's missing a couple of cylinders
I will try 33psi at front and 36psi at rear as per what is says on the door sticker. I have new michilens tyres fitted.
Also check the rear wheels (brakes) aren't hot on one side compared to the other. After a journey
So adjusted the pressures to 33psi front and 36psi rears. Driven it around lots of twisty roads and roundabouts and it's behaved.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I had a very similar problem to you though the effect varied sometimes. Had steering sensor done, made it slightly better. Played around with tyre pressures, no discernible difference. It was a real pain with a trailer on the back!
Hmmm.. that's food for thought. I do have brembos and have had constant sqeauling brakes for ages. What you say does make alot of sense. This is definitely something I will look into if problem persists.
