Home > General (L494) > Access mode
Lindab
"If you are drilling a hole in it, there's not much point having it fitted at all."
Censored Rolling with laughter Rolling with laughter Your correct Thumbs Up
 Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #623277 Fri Apr 01 2022 11:01am
Tyrefitter
Yes it is a exhaust,when adjusting height you can here it in the car without it,,you say if I put a hole in it why have it there at all.Then why does the new one come with a hole in it,when fitted with the hole in it you cannot here the air when adjusting the suspension so hey presto it works. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #623279 Fri Apr 01 2022 11:13am
Lindab
Andy, you lost me there
Probably because no one thought of leaving it out
Surely if its not there you still cannot hear the air when adjusting suspension Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #623281 Fri Apr 01 2022 2:03pm
Tyrefitter
What I’m saying is if you purchase a new filter for the exhaust side of the compressor they have a hole down the middle as opposed to the early models not having a hole,,so probably because of the problems with the early ones causing problems with the suspension they fitted ones with holes to eliminate the suspension issues. Smile
If you leave it out altogether you can hear the air inside the car which can be annoying. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #623282 Fri Apr 01 2022 3:35pm
Kitchenfitter
Ok you guys now created a mine field for me lol RRS HSE DYNAMIC 2015 ODESSEY RED
Post #623293 Fri Apr 01 2022 7:55pm
Grimble
There will still be some kind of silencing effect, think along the lines of a silencer on a gun. The noise will be generated by a narrow port in the valve block so the sound waves caused by the high velocity of the air exhaust will still be baffled by the exhaust but not as effectively as if the exhaust were whole.
A proper solution would be a larger exhaust, but I'm not familiar with the space available so maybe its all that would fit. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #623353 Mon Apr 04 2022 10:47am
