Home > General (L494) > L494 TPMS question
Dave-t
L494 TPMS question
A follow on to my spare wheel adventure!
The wheel I bought didn’t have a TPMS sensor in it, so I have bought a genuine one and had it physically fitted but the wheel is back in the boot, where I don’t believe there is a sensor pick up.
My question is, do they have to be coded or anything to work or do I just bung it on the car and go for a drive to be found? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #601626 Sun Jul 12 2020 5:32pm
Tyrefitter
Best way to find out is let the pressure out of the spare & see if it comes up on the dash,(spare tyre low pressure) If it does then it is fine to go,pump the tyre back up till you need it.Their is a sensor detector in the boot for the spare. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #601627 Sun Jul 12 2020 7:33pm
Dave-t
I don’t think I have that, when I had my space saver on and no spare, I’m sure the only alarm was for the wheel position. Joined the X5 45e club
Post #601630 Sun Jul 12 2020 8:23pm
scarey
the manual says that the sensor will be picked automatically..
Post #601631 Sun Jul 12 2020 8:26pm
Dave-t
Thumbs Up Joined the X5 45e club
Post #601632 Sun Jul 12 2020 8:32pm
Post #601636 Sun Jul 12 2020 11:38pm
Tyrefitter
Mine came with the full size spare so it will have already been programmed,I didn’t realise you had a space saver before,space savers don’t have the sensor fitted. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #601637 Mon Jul 13 2020 4:25am
May need the bead broken again on the tyre so you can read the eight digit I.D code on the sensor unless you happened to write it down first before fitting it.
Just wondered if you actualy ran the spare wheel on the car until it recognized the sensor and then swapped it back as a spare if it would retain the code for it, just a thought as not sure there is sensor aerial thing for the spare.
Post #601638 Mon Jul 13 2020 5:11am
Dave-t
It’s in for a service next week, so will get them to do that.
Thanks. Joined the X5 45e club
Post #601639 Mon Jul 13 2020 6:31am
Dave-t
For future reference, my new TPMS monitor didn’t need coding to the car, just a quick drive and it sorted itself out. Just don’t know if I have a boot sensor, maybe just let the tyre down and try it Joined the X5 45e club
Post #602307 Mon Jul 27 2020 5:04pm
Tyrefitter
That’s what I did Dave,let the air out & it should come up on dash,,spare tyre low pressure. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #602313 Mon Jul 27 2020 5:58pm
Chaps, how do I check if my spare has TPMS fitted?
I realise now after someone asked me that I've never seen a warning/reading for the spare. --
Post #602533 Fri Jul 31 2020 6:56am
scarey
if it has a rubber valve then it hasnt..
Post #602541 Fri Jul 31 2020 8:03am
^ thanks, will check it later Thumbs Up --
Post #602545 Fri Jul 31 2020 9:39am
Dave-t
TPMS is a grey hard stem with a nut like this
https://www.ebay.co.uk/itm/GENUINE-RANGE-R...2749.l2648 Joined the X5 45e club
Post #602554 Fri Jul 31 2020 3:02pm
